Hello!
EM200 has been one of my favorites lately, and probably one mic desert island SDC capsule.
They can be pricey with import and shipping, however a guy on Ebay has lots of EM204 at lower price.
EM204 is same as EM200 but it has built in source to ground resistor (470ohm) and can't be biased properly for loud sources. Even with vocals it clips easily.
So i sacrificed one capsule to find out where this resistor is, and if it's easy to just cut the trace from the outside. Turns out it's quite easy, and this is the place where you need to make a tiny hole to do it.
Measure source to ground resistance after you are done to make sure you did it right. Hole should be sealed afterwards because of polar pattern.
While we are here, does anyone know which FET this is, the one on the bottom image? Marking seems to be DJ but i am not sure. 2sk4027?
This is the trace we are cutting:
![4Z6d2tG.jpg](https://proxy.imagearchive.com/858/858327f7c09974a1541bcbb9189ad85d.jpg)
![Er6suwB.jpg](https://proxy.imagearchive.com/035/0354104ac9feb5480b6fa50bd88847f2.jpg)
