Svart
ok so i have a pair of these and they are decent enough, however I opened them up the other day to take another look inside and noticed something that I am not familiar enough with to know if it is correct or not.. The rear portion of the capsule is a clear plastic with holes drilled through it, and the front portion is brass with holes through it. the holes are arranged in rows in both pieces that *could* align with each other perfectly but seem to be rotated 90deg from each other. now, my question is: what would happen if you aligned all those holes up? does the rear membrane also have a tension like the front and how do you tighten them up?
I haven't touched the capsules yet since i don't know a thing about them and wish to NOT screw them up. i haven't opened any other LDC mics to see how they are made either.
:thumb:
:thumb:
