48v, pad and phase kits for pre's?
cedric
Active member
i can only find this kit on the web.
it's in australia, and i kinda need some kits now :)
plus i'm not even sure how it works?
has anyone tried these? how can there be a wire out for the 48v phantom (ext. PSU?)?
http://www.jlmaudio.com/kits.htm
I just follwed the Jensen mic input schematic.
http://www.jensentransformers.com/as/as016.pdf
I'm going to add the pad to my API pre, I already have +48V and Phase. Trust me, you need the pad on an API. I should have listened to the ones who tried to convince me...
[quote author="cedric"]how can there be a wire out for the 48v phantom[/quote]
That's an in, not an out. I.e., You need a phantom PSU.
Peace,
Al.
Hey Cedric,
I've used JLM's go between kits and power supplies & they're great... easy to put together & Joe's an awesome guy to deal with. Al is right, the go betweens are just switching units you'll still need a 48v power supply, Joe's are good - his 3 rail power supply (depending on transformer choice) can output up to +/-34v and a separate 48v rail. Where are you anyways?? Most of the shipping companies are pretty quick, my standard for small packages from the US is about 4 working days!!
Justin.
i guess what i've narrowed my search down to is a simple switch to give me a 20dB pad on the output of my pre's.
just a simple switch.
but i have no idea what kind of switch to look for... DPDT ?
and to get the correct 20dB pad i must know the output ohm of the pre's right?
you can wire a pad onto a dpdt no problem.
Id suggest using an H pad and not a U pad, I foudn that they sound much better. I know this must sound absurd to some people but Ive built both over the years and the H pads always seem to sound more transparent than the U pads (which makes less sense as there are two more resistors, go figure).
dave
could someone please draw me up a nice "schematic"?
http://www.myonlineimages.com/Members/blindboyrecording/images/20dBpad%20DPDT%20switch.jpg
you only have to copy the picture, draw some lines, add some impedances (4 x 650 R1 and 250 R2 ohms?) and you've helped me a great deal.
[quote author="Family Hoof"]With the H pad you can match impedances on both... [/quote]
You can also do that with a U-pad. Remember, we're matching UNEQUAL impedances. With a mic, you generally want to reflect about 2K to the mic and 200 ohms to the preamp, and a properly-designed U-pad will do just this. If you use a "regular" (equal impedance) H-pad, you're either loading down your mic or reflecting too high of a source Z to the preamp. You can design an H-pad for unequal impedances; but if you want to present a high input impedance and a low output impedance, there's no point in having to use the extra resistors.
If you used a 150/150 (or 200/200) H-pad on a mic and thought it sounded more "transparent", it's likely that what you heard was the loading on the mic, attenuating the mids and lows.
There's no accounting for taste, but a pad like the one Neeno posted is technically the better one to use. I'd prefer to use 1K and 220 ohms (instead of 680 and 150), but it's a minor difference.
jdbakker said:
Whoops said:
So what would be the benefits of using 1k and 220ohm compared to 680 ohms and 150ohms?
http://www.groupdiy.com/index.php?topic=35433.0
JDB.
Thanks a lot for the link JBD
emrr said:
1k/220r and 619r/169r 'U' pads arrive at same gain result.
1k/220r = crudely 2k22 load to mic and 220r source to preamp.
619r/169r = crudely 1k407 load to mic and 169r source to preamp.
Any mic and preamp combination may like one or the other better.    One loads the mic a bit more heavily, both are reasonably speaking correct bridging relationships.  With a transformer coupled preamp, the source presented to the input may be the more critical aspect with some transformers.
But I  still don't know if I should one or the other.
Why some people preffer the 1K/220r ?
it's because of their mic and preamp combination that works better with those loads, or because it provides safer overall loads?
