sdc tube mic
ioaudio
vienna/austria
i´m really happy and surprised with the sound of this one. i recommend this circuit for the ck1 /ck3 (cardioid) capsule for
everyone who feels that the sound of the c451 is not suitable for voice.
circuit is close to the g7 (thank you, jacob!)
*edit: missing 2.2µ cap (15k to ground)
*edit: missing 100n cap (trimmer´s whiper to ground)
some pics
http://groupdiy.twin-x.com/albums/userpics/10055/sdc_tube_mic_top.jpg
http://groupdiy.twin-x.com/albums/userpics/10055/sdc_tube_mic_inside.jpg
http://groupdiy.twin-x.com/albums/userpics/10055/firstmic%7E0.jpg
standard circuit
You might want to make the trim pot into two resistors with a cap from the 1g and two voltage divider resistors node to ground.
Assume the wiper of a trim pot will lift with time or corroded
Use the trim to find the ratio or calculated it knowing the B+
I do like how you build stuff.
in fact there is a 100 n cap from the wiper to ground, i simply forgot to draw it...
when my supply is finished (i use my bench supply for now) and i have a fixed b+, i will change the trimmer to fixed value resistors.
thanks for your kind words!
psu (12x9x5cm):
http://groupdiy.twin-x.com/albums/userpics/10055/sdc_tube_psu.jpg
choke:
http://groupdiy.twin-x.com/albums/userpics/10055/choke.jpg
replaceable grille with build-in pop-filter:
http://groupdiy.twin-x.com/albums/userpics/10055/sdc_tube_mic_grille.jpg
Very funky mic!
I have three CK1 and two CK3 capsules, but only three C451 amplifiers, so two of those nice capsules are laying around unused. I would like to try your preamp-design on them.
My question is: where did you get the connector for the capsule? Directly from AKG as a spare part?
Do you have sound samples? I always felt that the CK*-capsules seem to be a little bit too bright (cool on rock-overheads, "to cool" for recording classical instruments, where my C480/CK61 are much better...). Any chance that the tube and the oep reduce this a bit?
Toff
thanks. at this time i dont have any soundsamples, but soon i´ll try recording voice for a project.
my connector is from a worn-out c451, maybe you can get it from akg (i´m not shure...) or you have to find a machining shop.
locating an ef12 is hard as well, try finding a ef12k (less noise&microphonics)
while testing i prefered the ef12 over the ef86, it seemed more melow to my ears-bringing down the "crisp" from the capsule a bit.
I see you are underheating it at 5,8v, instead of 6,3v...
Did you do listening tests and liked the underheated tube better?
