JW
I attatched this question to a thread over in the Black Market, but I thought I'd ask it here, to be proper.
I'm another one of the folks wiring up output transformers to the PM1000 channels.
I've tried a couple Cinemags that someone reccomended (the CMOQ-2 series) and I've also wired up the original Tamura.
I've wired up the Cinemags @ 1:2, and when comparing a Cinemag channel to a Tamura channel, I noticed that indeed, I can get more gain out of the Cinemag, but it's at the cost of a lot worse headroom.
I get an avalanche of noise when I'm really pushing the gain when using a low output mic.
Anyway, I need to contact Cinemag again. I lost the diagram as to how to wire the Cinemags 1:1 and try that out.
But I thought I'd ask why the headroom is so bad when I wire those babies at 1:2. Compared to the Tamura, I'm really not getting that much more gain out of the Cinemag. So, I figure, 1:1 will be fine if it gives me better headroom.
Do you guys think wiring it at 1:1 will solve the problem? If that's the case, what's the theory behind why it works?
