META - SSL Clone posts
gyraf
Staff member
GDIY Supporter
Moderator
Aarhus, Denmark
This is a meta-thread, made to allow you to keep track of the posts concerning this single issue - I will continue re-editing this first post.
- All should be contained in this first post - which is re-edited regularily.
- Everyone is welcome to reply with comments and pointers to things they consider relevant. This will be copy/pasted into the first post.
- On a regular basis, we delete all posts but the first, and bumps it to the top.
https://groupdiy.com/index.php?topic=47
GSSL HELP THREAD!!! - The extremely-long help thread for the GSSL. From 2017 reserved for the "vanilla" version, mods and updates in the separate thread:
https://groupdiy.com/index.php?topic=65232.0
GSSL add-on help thread - for everything beyond the vanilla GSSL.
http://www.gyraf.dk/gy_pd/ssl/ssl.htm
The GSSL DIY-page at Gyraf/DIY
http://www.gyraf.dk/gy_pd/ssl/parts.html
Kev's parts list for the GSSL
http://members.cox.net/capstanrecording/SSLCloneParts.pdf
This is a nice BOM from Greg. It breaks down what type of caps are used where. Very comprehensive and a direct link to a BOM for North Americans.
http://www.groupdiy.com/index.php?topic=47
SSL help thread? - this should be the main fixing-trouble thread. Post technical problems with building the unit here.
http://gssl.rolandklinkenberg.com/
Roland's very nice site showing the construction of his authentic-looking unit
http://www.groupdiy.com/index.php?topic=2566
SSL comp question to Jakob - About possibly confusing differences between schematic and pcb versions.
http://www.groupdiy.com/index.php?topic=21984
GSSL VCA Variations & Resistor Value changes - on getting the different VCA types working right in there
http://www.groupdiy.com/index.php?topic=4959
signal to noise in the GSSL comps. - on (non-existing) noise issues, measuring s/n ratios.
http://www.groupdiy.com/index.php?topic=14602
Calibrating the G-SSL with THAT2181 - share thread !!! - on fine-tuning the G-SSL for different VCA types
http://www.groupdiy.com/index.php?topic=2418
Taming the SSL's threshold sensitivity. - About modifying the threshold sensitivity of the clone
http://www.groupdiy.com/index.php?topic=331
SSL Clone Question? fault in my clone? - Problems with ratio switch and distortion at some release setting.
http://www.groupdiy.com/index.php?topic=4651
My SSL exploded! :( About what happens if you feed phantom power into the clone's outputs..
http://www.groupdiy.com/index.php?topic=8046
SSL Clone with no treble - what happens if stabilization capacitors are wrong..
http://www.groupdiy.com/index.php?topic=798
SSL clone help - on problems around the threshold and makeup gain circuits. Symptoms: Meter works, but audio does not change.
http://www.groupdiy.com/index.php?topic=5324
SSL help needed. Please. again - Symptoms: Meter works, but audio does not change.
http://www.groupdiy.com/index.php?topic=1274
1176 Type "SLAM/NUKE" mode for SSL?? - On possibly implementing the "Crush"-function
http://www.groupdiy.com/index.php?topic=177
ssl external sidechain - on adding a sidechain input/insert to the basic design.
http://www.groupdiy.com/index.php?topic=5356
SSL mod: extra gain - about getting unity gain through the unit
http://www.groupdiy.com/index.php?topic=1379
SSL : bal. / unbal. / 6db ? / 15k <-> 27k - On unity gain - again
http://www.groupdiy.com/index.php?topic=944
SSL Clone compressor ratio measurements - On how to correct Ratio's if they come out wrong
http://www.groupdiy.com/index.php?topic=408
ssl mod questions - about possibly modifying the circuit.
http://www.groupdiy.com/index.php?topic=27
SSL servo files - DrFrankencopter about getting rid of coupling capacitors..
Behringer Meters on SSL Comp - about the round Behringer meters suitability for the Clone.
http://www.groupdiy.com/index.php?topic=3575
Does this edgewise meter work in the SSL? - Nice Mouser meter for the Clone
http://www.groupdiy.com/index.php?topic=9634
Led-meter for the SSL comp...?? - Using led-meter in stead of the moving-coil types
http://www.groupdiy.com/index.php?topic=358
if you are building an SSL clone with THAT2180 series... - on what to change when using That2180's in stead of 2150's
http://www.groupdiy.com/index.php?topic=12641
SSL-clone: electrolytics bypassing - On bypassing or not bypassing certain electrolytics
http://www.groupdiy.com/index.php?topic=291
SSL Compressor Parts Question For North American Suppliers - TubeJay's sourcing-parts list.
http://www.groupdiy.com/index.php?topic=20248
Stupid parts question - On component types and ground
http://www.groupdiy.com/index.php?topic=1311
Newbie ssl question... - starting questions
http://www.groupdiy.com/index.php?topic=7619
SSL resistor specs - on wattage of the used resistors.
http://www.groupdiy.com/index.php?topic=68
SSL Clone Parts - about locating the original type knobs and switches.
http://www.groupdiy.com/index.php?topic=1291
GSSL engraved panels anyone? - Svart's .FPD files for the frontplate of the GSSL
http://www.groupdiy.com/index.php?topic=236
SSL PCB connectors and 10 pole ribbon cable...where to find - on sourcing the PCB connectors used for connection between boards
http://www.groupdiy.com/index.php?topic=20433
Grounding input & output XLRs on SSL - a little question - Grounding and mounting
http://www.groupdiy.com/index.php?topic=48
Anyone have any 2150 VCA's they'll sell me for the SSL comp? - name says it all.
G1176 and SSL Comp PCB's - Thank you! - Feedback on the PCB's from Gustav.
http://www.groupdiy.com/index.php?topic=5881
my first ssl success (pics) - pics of JayDee's very nicely built unit
http://www.groupdiy.com/index.php?topic=23162
SSL completed as well ... - pics of Chuck D's clone
http://www.groupdiy.com/index.php?topic=1837
Another SSL Finished (pics) - Pics.
http://www.groupdiy.com/index.php?topic=7205
Another GSSL is born today - On using the pre-trimmed 2180 and altering threshold sensitivity.
http://www.groupdiy.com/index.php?topic=62
Aphex VCA - part two - This contains a link to a nice article by Ben Duncan about the DBX VCA's, as well as some others. Good theory.
http://www.groupdiy.com/index.php?topic=8897
My GSSL - finally finished - also describing construction and use of an API "thrust" type tilting sidechain filter - including layout by Svart..!
http://www.groupdiy.com/index.php?topic=12024
Steffen's GSSL High Pass Filter Documentation describing in-detail a  high-pass sidechain filter.
http://www.groupdiy.com/index.php?topic=16113
GSSL SuperSC board (clintrubber schematic)
SSL clone: enhanced input & output section
http://www.groupdiy.com/index.php?topic=8174&start=0
"Thrust" filter:
G-SSL Side-chain (Stephen's HP + Dual Thrust HP filter) !
http://www.groupdiy.com/index.php?topic=14835
SSL-sidechain overkill by means of 2 T*h*r*s*t-circuits
http://www.groupdiy.com/index.php?topic=12749
SSL THRUST CIRCUIT
http://www.groupdiy.com/index.php?topic=10498
Which Hi-pass filter for G-SSL ???
http://www.groupdiy.com/index.php?topic=13272
"Oxford" mod (dual sidechain a'la original):
New 'ultimate' SSL buss comp clone ;-)
http://www.groupdiy.com/index.php?topic=18017
GSSL Turbo board complete!
http://www.groupdiy.com/index.php?topic=27275
Circuit analysis:
Help needed understanding SSL Mixbus RATIO circuit
http://www.groupdiy.com/index.php?topic=45872.0
GSSL Ratio Mod adding 1.5:1 Solved
http://www.groupdiy.com/index.php?topic=49854.0
..Have fun!
We love our DIY.
Jakob E.
