Transistor replacement for green pre
frezen
Member
Norway
Hi all
I have problems locating the BC560 locally, I can get hold of BC557, is this ok as a replacement or can any recommend something else. I am looking for quality parts and are reluctant to compremize on noise level.
Regards
Frode
Hi again
and thanks for quick replies.
The BC560 is a PNP, why should I replace it with a NPN?
Regards
Frode
[quote author="frezen"]Hi again
Regards
Frode[/quote]
Interesting question...
Do you also want to know why gear doesn't work when you insert batteries reversed ? :wink:
Kidding aside, for now think of it as the 'polarity' of transistors. And try to read about 'bipolar transistors', 'BJT', semiconductors in general etc.
Bye,
Peter
I have problems locating the BC560 locally, I can get hold of BC557, is this ...... I am looking for quality parts and are reluctant to compremize on noise level...[/quote]
BC560 is used here in the CS circuit in LED display. Almost any TUP will be good for this purpose.
The BJT's noise figure here isn't important.
Regards,
Milan
[quote author="moamps"][quote author="frezen"]
[/quote]
:oops: I was obviously mistaken, was just thinking of the signal-path, not the LED-circuit :oops:
Indeed, about any Si-PNP will be fine there.
