moqtev
Hi all!
Last week I set up a an eight channel analog summing box like the based on New-York-Daves schematics. I used a couple of Telefunken V672 as amps.
With a friend I made a blind test to see if there was a difference between doing different mixes using the mix bus of my computer system or sending different groups of the mix into the summing box. We also tried doing analog summing with a small Mackie 1404 mixer.
The computersystem is Mac G5 dual 1.8Ghz with Logic Pro 7.1.1 and MOTU 2408 mk II PCI424 based hardware.
...and the result: more noise in the analog summing version, but no difference apart from that :shock: :shock:
The noise was better from the Mackie but no sound difference that would make it worth the trouble.
It should be noted that this is a subjective test. We haven't made any scientific measurements but have been listening for things like wider stereo image, intrument seperation, bass, air, headroom etc. things we strive for when doing a good mix
The mixes we did had between 24 and 60 tracks....next step will be my friends Pro Tools HD192 system.
Well that is my experience so far - I would love to hear about your experience?? :razz:
Morten
Morten
