No, driving 50 ohm is not normal. An IC opamp may go into current limit. IC based output? Schemo?I have an audible oscillation problem with a preamp, but it only happens when I try to drive very low-impedance loads (eg. 50 Ohms). Is this normal?
There are two strong mechanisms working against each other--the feedback wants to supply more current and the output protection wants to supply less current. That makes the system somewhat unstable.How could Current limiting cause this problem?
Well harmonics are always of higher frequency than the fundamental and aliasing happens only in time-discrete systems (e.g. digital).I wonder if this is simply a harmonic or an alias product...
