Royer Power Supply/ 5840 Questions
starfish
Los Angeles
Hi, I'm building a power supply for a Royer SD tube mic using one transformer for B+ and a separate regulated DC ps for the tube heater. Does the heater supply need to be referenced to ground or should it float? Also, I was wondering what the difference in plate current is when using the 5840 as a triode as opposed to a pentode. I have the data sheet for pentode operation but haven't seen any info on triode use.
I didn't read the above properly or even think about it
but
here is a presentation of one of Dave's projects
http://www.diyfactory.com/projects/royerproject/royerproject.htm
there might be something on there that can help
Thanks Kev, but the link wouldn't open for me. To be more clear, I have a transformer with a 110v secondary for the B+ and an Acopian 5v DC module that I would like to use for the heater supply. Do I just connect the 5v to the heater, or do I need to connect the negative side of the 5v output to chassis ground?
My favorite version of a Royer design: the Franken-phone.
Is your DC supply +/-5VDC, or is the neg just ground? Also, what does it meter at unloaded, should be above 5V? You might not want to underheat too far. FWIW, the RCA Datasheet (PDF) says 6.3V +/-5%.
Since the 5840 doesn't have a center-tapped heater, I think you just connect your two leads to pins 3 and 6, but wait for someone more knowledgable to confirm that.
Good info on Heater connections in this thread: http://www.groupdiy.com/index.php?topic=9797
Several of the datasheets available on Frank's Electron Tube Pages have plate curves for triode connected operation.
pentode triode switch anyone see a good use for this ?
i like em in gtr outputs but that , of course is different
regards Greg
[quote author="starfish"]Thanks Kev, but the link wouldn't open for me. [/quote]
I've checked it from 3 different locations
sorry but I don't know what's wrong
try refreshing a couple of times
Thanks guys, I found the triode plate curves. Still can't get Kev's link to open. So 5v might be a little low. I haven't gotten to measure the voltage on the module, and have to work long hours for the next few days so I have to set this aside for now. DIY withdrawl!
[quote author="starfish"]... Still can't get Kev's link to open. So 5v might be a little low. ...[/quote] :sad:
bummer
try a cut paste into a new browser window
do other Factory pages work ?
or a fresh one like
http://www.diyfactory.com/projects/fetboy/fetboy.htm
Kev, I can't get any of them to open. I tried cut and paste in the original window and a new window in both Safari and Explorer. I know I've been to your site before, but that might have been at a friend's house or at the library before I had a computer. ???!
:sad:
perhaps your ISP is blocking the Factory ... :shock: ... :wink:
I just don't know ... sorry
I hope it cure's it's self one day
