JRE Productions
Ok, I tried searching the meta, but there is an overload of information. I have used several original 1176 (mostly early blackface, not the earlier blue stripe). I like the sound, but will not have one to directly compare mine to.
Dillema: I just completed stuffing two boards. The rack boxes are identical except one is a painted face the other is anodysed. So the next question is, do I add input transformers on both or one? I bought enough OEP to do either. Yes I could build both and try myself, but unstuffing the balanced input sections is not the cleanest work. And once I have it wired up, I probably will not take it back apart.
Has anyone built both styles? Which one gets used more? Will I later wish I had a matching pair vs two different versions?
I record mostly BLUES, Jazz, Swing and Country. But sometimes something more like funk. Never Rock or Metal....
Joe
Joe
