bigugly
I just got TubeCad from Glassware. What a fun app. Anyway, I drew this up based on my tinkering with TubeCad.
It has a grounded grid for the first gain stage to a grounded cathode second stage then to WCF. I went with a grounded grid on the input because I have several 1+1:2+2 input xfmrs that I'd like to use for something. The output iron is a Cinemag CMOQ-1L set up as a 2:1 step down. TubeCad says I should get 30db from the first two stages each and since the input and output tranformer gains cancel my net gain is 60db. The only thing I haven't sorted out yet is where I will put my gain control. The easiest would be to put a pot in-between the first and second stages but I was also thinking I could use feedback from the output to the first stages cathode.
I'll start building this next week when I pick up the Cinemags.
cheers,
James
cheers,
James
