Small watt Gtr amp single ended
Vetsen
Utah
I have the basics of a small watt gtr amp completed. All that is incomplete are the transformers. I have a power transformer that I bought here from a member, but it doesn't have a center taps on the secondaries.
I don't know much about gtr amps. I have looked at several schematics and all seem to have a center tap. Is there anything I can do to be able to use this power transformer?
On the AX84 project, there is what looks to be a half wave rectifier and a center tap. If I use a full wave rectifier, like on the G9, can I get away without a center tapped transformer? Or will that cause other problems (like a higher voltage), maybe safety issues?
Vetsen
[quote author="Vetsen"]I have the basics of a small watt gtr amp completed. All that is incomplete are the transformers. I have a power transformer that I bought here from a member, but it doesn't have a center taps on the secondaries.
Vetsen[/quote]
Full wave rectifier is on AX84 (two diodes and 2x250V C.T.)
You can make a supply using a transformer without a center tap if you use a full-wave bridge rectifier. What's the voltage of the HV secondary on your transformer?
Peace,
Paul
