News:
Site maintenance in progress (expect intermittent wonkiness). Thanks for your patience!
Freq Band
Slider pot lube
« on: October 28, 2006, 06:15:31 PM »
What is the "greasy" stuff inside a sliding pot ?
I cleaned a couple, with contact cleaner. Was that an oops?
Cailube does not provide that "silky smooth" action.
It's hard to get inside the pot.
Do I need to actually open it up all the  way (bend up those crimp tabs?)
=FB=
Facebook is an unfortunate way to receive news, and a good place to receive rumors.
mr coffee
Slider pot lube
« Reply #1 on: November 07, 2006, 10:53:28 PM »
Silglide silicone grease.
SSLtech
Slider pot lube
« Reply #2 on: November 08, 2006, 03:18:02 PM »
Careful...
I believe that the GPO (before the days of British Telecom) found that silicone products can degrade contacts over time... which begs the request for the original poster to be more specific with the question:
When you talk about putting this stuff on pots, do you mean the contact/track area or the rotary/bearing area?
Caig is for one thing, but NOT the other, vice-versa for Silicone-related products.
Keith
"A waist is a terrible thing to mind"
Quote from: PRR
Ah, but that was 1999; we don't party like that any more.
Slider pot lube
« Reply #3 on: November 08, 2006, 03:43:15 PM »
Did anybody try DeoxIT? I used vazeline long time ago back in Russia, it worked well. But I can't find it here...
Marik
Slider pot lube
« Reply #4 on: November 08, 2006, 04:23:21 PM »
Quote from: "Wavebourn"
Deoxit D5 works good on connectors and switches... smells bad, though.
You can find vaseline in your local Walgreens.
Samar Audio & Microphone Design
www.samaraudiodesign.com
The Art of Ribbon Microphones
sodderboy
Slider pot lube
« Reply #5 on: November 08, 2006, 05:43:47 PM »
DeOxit should never be used on anything except metal, and it should be removed with a solvent before contact conditioner is applied.  The boss complained that it did not clean the volume pot on his stereo.  I opened it up and R5 had gathered like butter between the front panel and the chassis!
Vaseline is petroleum based, so I do not know if it is a good match with plastic.  If you are talking about cheesy sliding carbon faders, where you need to lube the plastic slider, I like a lube I got from MCM that is made for the moving parts in VCRs and the like.  It is Luberex made by GC electronics.
Mike
Slider pot lube
« Reply #6 on: November 08, 2006, 06:53:15 PM »
Thanks Marik!
I'll check in Wallgrins. Made for usage on fine parts of human body it does not contain any agressive additions.
Marik
Slider pot lube
« Reply #7 on: November 08, 2006, 10:25:42 PM »
 :grin:
-дэвушка, тэбэ с вазылыном ылы бэз
-с вазелином... пожааалуйста
-Вазэлын захaды
Slider pot lube
« Reply #8 on: November 09, 2006, 01:19:10 AM »
Quote from: "Marik"
 :grin:
-Вазэлын захaды
Са свэтом спать будэш?
Да!
Свэта, захады" :D
Marik
Slider pot lube
« Reply #9 on: November 09, 2006, 01:24:40 AM »
Грузин стоит на остановке. К нему подходит иностранка:
Excuse me, do you speak English?
Канешно хачу.
Slider pot lube
« Reply #10 on: November 09, 2006, 05:47:58 PM »
Quote from: "Marik"
Канешно хачу.
Here you go:
Marik
Slider pot lube
« Reply #11 on: November 09, 2006, 05:53:25 PM »
$2.99 a jar, I believe...
Is it TOA 208?
Slider pot lube
« Reply #12 on: November 09, 2006, 06:03:13 PM »
Quote from: "Marik"
Is it TOA 208?
It was called TOA-216 when I bought it. ;)
Very good construction, but Japanese designers did not know some audio art details... Cheap base for excellent project.
Big can of vaseline costs $4.99
...since you can read Russian... http://www.wavebourn.com/index.php?topic=16450#16450
Marik
Slider pot lube
« Reply #13 on: November 09, 2006, 07:02:47 PM »
Yeah, I can read, but can't type. I actually even don't have Russian keboard (was using virtual one), and it takes me half a minute to find right letter :sad: .
Translate it and post here. I am sure many folks would be very interested--those TOAs are very cheap (often under $100 on Evil-Bay, before your post :razz: ).
Question, why do you need that much gain? Maybe a triode?
I used a cascoded 6N1P (Russian :wink: ) with a FET on bottom. Sounds very nice.
Slider pot lube
« Reply #14 on: November 09, 2006, 08:47:25 PM »
I will go with +4 dB levels instead of 0 dB like in the original TOA console.
Last post July 20, 2004, 09:22:32 PM
by daArry
Last post June 22, 2005, 12:59:20 PM
by quadwould
Last post March 07, 2011, 10:16:09 PM
by Govinda Doyle
Last post October 05, 2011, 09:09:57 PM
by opacheco
Last post January 25, 2012, 08:22:47 PM
by opacheco
