MILA layout
Nadege
Belgium
Hello
here are my layout for the MILA project
http://www.twin-x.com/groupdiy/displayimage.php?album=lastup&cat=0&pos=1&uid=31
could anybody check it ?
Thanks a lot
:wink:
hi can anybody check this?
I also have question about wich kind of fuse to use fore one channel of the MILA ????
I peter I need to know If I haven't made a mistake somewhere in my layout... I was very carefull when drawing it with the schematics next to me, but who knows, maybee something isn't rigth.....
Hi Nadege,
Those layouts look right to me; there's just a couple things I wanted to make sure you're aware of:
1) Pin 1 of the 12AV7 on the left should connect to left side of R8/top of C3
2) bottom of R9 goes to ground
3) left side of R16 to ground
4) Pin 1 of the 12AV7 on the right should connect to top of C6/C7
5) right side of R10 (top of R9) connects to wiper of VR1 (looks like you got that one)
6) what???!!! no labels for R4 and C1??? :green:
7) the range switch assembly is a little hard to read
I've uploaded New York Dave's original MILA schematic here since his "One Bottle" and "Mila" threads seem to be plagued by broken links/missing info: http://www.musiciansgig.com/mila/MILA1-Updated.pdf
Hope that helps,
:thumb:
Martin
Hi everybody
I'm back with the MILA project.
Here is a link to my updated layout following madriannse's instructions (thanks :thumb: )
http://www.twin-x.com/groupdiy/displayimage.php?album=87&pos=2
And here are some photos of my unit not tested yet..... :? (I'm a bit afraid of powering this baby :wink: )
http://www.twin-x.com/groupdiy/displayimage.php?album=87&pos=3
http://www.twin-x.com/groupdiy/displayimage.php?album=87&pos=4
http://www.twin-x.com/groupdiy/displayimage.php?album=87&pos=5
http://www.twin-x.com/groupdiy/displayimage.php?album=87&pos=6
http://www.twin-x.com/groupdiy/displayimage.php?album=87&pos=7
http://www.twin-x.com/groupdiy/displayimage.php?album=87&pos=8
I hope this time the links are working...
Comments are more than welcome
:green:
I get the case from RS component it's referenced as number 215-5253 and the dimensions are 270x190x70mm
[quote author="Nadege"]Hi,
I get the case from RS component it's referenced as number 215-5253 and the dimensions are 270x190x70mm[/quote]
hmm now to convert MM inches :wink:
[quote author="pucho812"]True dave but this is a lil easier
http://www.onlineconversion.com/[/quote]
Nah, this aint easier, in google you can write for example "1 inch to cm" (without quotes) and it calculates for you.
and if you have a google toolbar it displays the result as you type.
