cannikin
Hey there,
I'm building some Tube Power Filter Section Turret Board thingys and trying to layout a general/generic design for the Filters supply.
I have a bunch of power Xfrmrs that I should put to use for various tube projects. This basic design is based off the Federal AM864/U limiter and Sta-Level filter section to use with 5Y3 rectifier. The Caps/Choke/Resistor Values will change depending on the Voltage needed and the voltage/rating of the available Xfrmrs on my shelf.
what you think of it? any thoughts/comments to be better? thanks
