News:
Site maintenance in progress (expect intermittent wonkiness). Thanks for your patience!
owel
Toroid transformer mounting kit
« on: September 22, 2007, 09:13:37 PM »
Anybody has any tip on where I can get toroid transformer mounting kits? i.e. the rubber pads, big disc washer, bolt, nut.
The toroid transformer does not have an epoxy filled center.
cannikin
« Reply #1 on: September 23, 2007, 12:32:35 AM »
Avel Lindberg
Tube limiters..yum!
josh
« Reply #2 on: September 23, 2007, 03:59:38 PM »
I got this awesome stuff from home depot a few months ago.  It's a soft blue rod with a white center.  You cut off a chunck, mix it with your hands and it is the consistency of putty.  Well, it is putty.  place it on or in what you want to use it for and in 15 minutes its hard as brick and stuck in place.
I would use this along with a bolt to fill the center with a bolt in place to make the hole.  when it dries, back the bolt out.  Viola...instant filling.  one tube was like 5 bucks, and I've used it to mount standoffs, hold nuts in place, and repair a hole in the vacuum cleaner tube.
Josh
« Reply #3 on: September 24, 2007, 07:17:44 AM »
Quote from: "cannikin"
Avel Lindberg
+1 called them up and they sent it FOC to the UK
Denyle Guitars
« Reply #4 on: September 25, 2007, 12:03:08 PM »
You can try a beaker stopper. You can get one that already has a hole. They're tapered and they expand as you tighten the bolt. It's a nice alternative if you're trying to squeeze a toroid into a 1u chassis.
You can also cut your own using a hole saw.
owel
« Reply #5 on: September 25, 2007, 11:25:48 PM »
Emailed Avel and still no response. I got these transformers from them too.
That beaker stopper looks like a neat idea. Link?
EDIT: Too expensive...
LewKellogg
Home Depot Stuff
« Reply #6 on: September 26, 2007, 09:34:46 AM »
The Home Depot stuff sounds great - What is it called? Or, what section is it in?
Lew
Lew Kellogg
Kings Mill Audio
owel
« Reply #7 on: September 26, 2007, 11:06:32 AM »
Duhhhh... ignore my post guys. I feel stupid.
I called Avel and told them I did not receive mounting kits from my order of transformers, and spoke to someone on the phone, she told me to look under the box and there they were... all 25pcs of them.
Problem solved.
Denyle Guitars
« Reply #8 on: September 26, 2007, 11:11:10 AM »
Quote from: "owel"
Dude, they're like 50 cents for the big ones. Try searching for "test tube stopper" and you might get more hits.
If you go with the epoxy filled center idea, you can also try gas tank repair epoxy. Comes in a stick, you just knead it for a minute then shove it the hole.
owel
« Reply #9 on: September 26, 2007, 11:32:47 AM »
I googled "beaker stopper" and they're in the $2-$3 range for the size I need.
« Reply #10 on: January 25, 2008, 11:55:56 AM »
Does anyone have pics of the toroid attachment kits and the  monting hole???? :cool:  :cool:
shabtek
hmm
« Reply #11 on: January 25, 2008, 08:29:44 PM »
like to point out that the epoxy stuff may not be as reliable as we'd like:
if it is brick hard it may stress the windings as they expand/contract when heating up.
i wonder if the proper epoxy is slightly flexy?
it is a convenient way to mount a torroid--tape over the bottom side hole, flip over, fill it most the way up and drill a hole for the bolt when the stuff cures
"really fine players do not use stomp boxes or master volume, they match the amp to the room and turn it up to 11.  Stevie Ray, BB King, Albert King, Duane Allman, Dicky Betts, Louis Armstrong"
   -CJ
owel
« Reply #12 on: January 25, 2008, 09:13:18 PM »
Quote from: "tonebucket"
Scroll down to the Power Transformer kit.
http://fivefishstudios.com/index.php?option=com_wrapper&Itemid=45
« Reply #13 on: January 26, 2008, 09:17:05 AM »
Quote from: "owel"
Thanks for the reply. :grin:  :grin:
I am surprised the kit uses a metal pin as that would effect the magnetic field of the transformer!!
s2udio
« Reply #14 on: January 26, 2008, 10:35:19 AM »
Only if you short it out  :!:  :shock:
on the end of a piece of wire
« Reply #15 on: January 26, 2008, 11:01:52 AM »
I may have a better idea on how to mount it than using a metal pin.
Does anyone know how much a toroid transformer weighs?? :grin:  :grin:
owel
« Reply #16 on: January 26, 2008, 01:07:57 PM »
Here are more ways to mount a toroid.
http://avellindberg.com/transformers/custom_designs.htm
Per the Avel website: The metal chassis should not touch both ends of the mounting bolt. This causes a shorted turn, which would overheat the transformer rapidly and cause its destruction.
« Reply #17 on: January 26, 2008, 01:32:40 PM »
Quote from: "owel"
Thanks for the link :wink:  :wink:
My thoughts
Polyester tape, might not hold the transformer in place.
A Metal can would inhibit air flow and effect the magneticfield, an  enclosure would inhibit air flow.
Last post August 25, 2004, 10:04:20 AM
by thermionic
Last post November 25, 2004, 01:40:27 PM
by isamee
Last post March 18, 2005, 11:51:01 PM
by PRR
Last post November 02, 2007, 10:22:31 PM
by Bluzzi
Last post May 31, 2016, 11:43:51 AM
by TheJames
