NewYorkDave
So, this know-it-all at work orders some big honkin' Community R.25s to replace some bullhorns in a 70V PA system. Problem is, he ordered the 4-ohm version . It's no problem to switch the amps to low-Z output (they're Crown CT-410s), but the line resistance is about 1.3 ohms. This is 12-gauge wire and the nominal output power is about 240 watts. We're stuck with this until we can buy some 70V stepdown transformers to mount at the speakers; we tried it today and it worked OK for the short time we tested. But I'm horrified to think of all the power being dissipated in heating the wire. How would I go about calculating the approximate worst-case temperature rise (steady-state output)? I just want to know if we're facing a potential meltdown until we can rectify the situation.
