Latest Fet Microphone Construction
zebra50
York, UK
This is Gus's latest FET mic. Have a good look at the construction. He has used a single metal bar to support the whole citcuit. The shell is an old fence post. I think it is a pretty cool way of building the mic. Gus will drop by and say a bit about the circuit and construction.
:thumb:
Its a mxlv57 capsule. The top one has the circuit that sounds good. the bottom picture is one with a small transformer it is to small the circuit would fizz at higher levels.
It's the simple km84 circuit. The top picture uses a homemade 5 PF cap(twisted red teflon wire) It is hard to find <20pf polystyrenes. It also uses a LL1636.
That capsule is only in it for a test. I made other top plates that I can mount capsules to to test. With the LD microphones you can get rid of a few parts of the stock KM84 circuit because the capsule does not have to have one side grounded. The circuit I use give up about 1V of capsule voltage and hase two less caps and one less resistor.
As I have said in the past i get about 4 fets that bias nice out of 100.
The body is a piece of fence tube I cut with a pipe cutter and hacksaw and files. The screen is 16X16 49% open steel I use a torch to solder in place. I machined the base on my lathe and used hand tools to make the backbone.
DIY with what you have is fun!!!!
That's too cool using a fence post! It's model # could be "FP-1". :green:
BTW, did you paint it with "Hammertone" finish paint? Looks good! :thumb:
Cool!
Now Gus, tell me... I assume that you have somewhere a tube mic with the same trafo--what do you say about difference between tube and SS versions?
BTW, does it have a PSU?
