mjk
Since the subject was discussed here some time ago, I thought I would share my ideas on building a compressor/limiter based on a beam deflection tube.
I looked at the characteristics of a few BDTs, and the 6ME8 stood out as allowing a pretty large linear deflection voltage swing, which is desirable in a limiter input circuit. The idea is to drive the audio voltage on the deflection electrodes.
I could have audio signals coming in at +30 dbu or more, which is about 70 volts peak-to-peak. Looking at the attached curves, the deflection voltage could swing 40 volts each way, in a diffamp giving > +30 dbu, before going into the nonlinear part of the transfer function.
The 6EM8 being a beam deflection tube, the control grid G1 sets the anode current and the deflection "plates" steer the beam to one anode or the other, the total current of the 2 anodes remaining constant.
Looking at the ratio of deflection voltage to plate current differential, using the deflection electrodes as a "differential signal grid" gives a Gm of approximately 175 at unity to 35 uMhos at max GR over the range of -6 to -9V on grid1. The operating range is shown in red and green for the respective 2 anodes
Grid 1 will be used to control the gain over about a 14db ratio, or a maximum 14db gain reduction. Not exactly a crusher but should be useful for a lot of tasks.
With respect to the G1, it the tube has a pentode characteristic and within the chosen operating range (in red) is quite linear over anode voltage. This implies that as the anode voltages change wrt one another as signal is output, the total current will remain constant.
It looks to me like a purely resistive load would give a fairly linear output, especially if the topology is kept balanced differential throughout.
One problem this limiter will have in common with so-called "variable mu" limiters is that as the control voltage increases there is a common mode output current step that can cause an annoying audible "thump" when the limiter is used at fast attack times.
In this operating range the common mode current over the range of CV is about 6 mA, and the signal current is about 7 mA p-p, so I conclude a simple resistor load on each anode is going to be trouble for "CV isolation". I think I'll start with a common mode choke like a LL1667, with a resistor load anode-anode chosen to give a 1:1 signal ratio from deflection plates to anodes when the DC anode current is about 8 mA per anode.
The sidechain amplifier only needs to swing 3V into the control grid of a pentode! Is this too good to be true?
Here's a simplified schematic. The input is transformer coupled with a signal balance network to null out the f2 distortion due to unequal signal swing through the signal path top vs bottom.
Then cap coupled to a DC balancing network to set the quiescent current balance between the 2 anodes by tweaking the deflection voltages.
The gain control voltage from the sidechain drives the control grid of the 6ME8 through a cathode current servo. Remembering that the signal doesn't change the cathode current, just steers the beam back and forth, this trick should help linearize the gain response to a 2-8V control voltage input.
Back to the signal path, the BDT anodes are loaded by a common mode choke that should provide the first rejection of the control voltage induced common mode thump signal while passing the audio at a level determined by the BDT current swing and the load resistance.
This then DC couples to the output stage which can provide controllable gain through the "plate feedback". The load resistor also has an adjustable center tap so that the CV thump can be balanced out and rejected by the diffamp output stage. The cathodes of the output stage are AC coupled but DC separate, allowing perfect DC balance and AC current sharing.
The output stage gain should be adjustable between 1x and 3x (0-10db) which is in the loop and will set the compressor's small-signal gain.
The output signal is taken back to the sidechain amp where it is rectified and processed for threshold, attack, release settings and applied to the 6ME8 current servo.
All of the balance adjustments make it look complicated, but I think they'll be necessary for good performance. I don't know how good the dynamic balance can be. One characteristic of this limiter may be an increase in f2 distortion as the Gain Reduction (GR) kicks in.
Michael J Koster
http://redwoodcoastmusic.com
Michael J Koster
