News:
ATTN: In the coming weeks there will be extended periods of downtime to upgrade our server. I will try to limit the extended downtime days to Saturdays when traffic is lowest, but overall service may be spotty.
Moby
Behringer B1 condenser mic schematics anyone?
« on: July 03, 2008, 09:07:56 PM »
I'm looking for Behringer B1 schematics   :green:
Moby
« Reply #1 on: July 05, 2008, 04:13:07 PM »
polite bump, anyone?
lofi
« Reply #2 on: July 05, 2008, 04:57:35 PM »
obvious question is why? :green:
wouldn't mind a look at them though
Iain
Are you professionally stupid, or just a gifted amateur.
Iain Westland (UK)
Moby
« Reply #3 on: July 05, 2008, 05:06:19 PM »
I try to help my friend...mic sounds like a S*h*i*t bu maybe some mod is possible... :cool:
Rossi
« Reply #4 on: July 05, 2008, 07:46:53 PM »
If you post a pic of the internals, chances are the circuit looks familiar and someone might point you to one of the familiar China-mic schematics. Lots of cheapo mics use very similar circuits.
"I am not a number, I'm a free man!"
"Hahahahaaaaaa!!!!!"
Moby
« Reply #5 on: July 05, 2008, 07:55:25 PM »
Quote from: "Rossi"
Thanks, possible...I will tell him to took a pic's of the PCB  :idea:
Moby
« Reply #6 on: July 05, 2008, 08:34:58 PM »
BTW is it capsule worth of...I'm not familiar wit behringer mics??
Moby
« Reply #7 on: July 08, 2008, 08:12:27 PM »
here are the pics of the "beast" ;-). Pics with parts and tracks ale aligned and rotated to drop into each other , so if someone try to trace don't have to bother with. I added the pics with capsule , maybe some of you can recognize the model . If capsule is worth of something maybe redesigning the electronics is the best solution ...don't know    :?
3nity
« Reply #8 on: July 08, 2008, 08:47:39 PM »
It looks a lot like the Studio Projects B1
Life is a path, death the destination.
Moby
« Reply #9 on: July 09, 2008, 12:09:25 PM »
Quote from: "3nity"
Cool, any schemo or idea about?
gyraf
« Reply #10 on: July 10, 2008, 03:44:15 AM »
PCB says "Beijing 797 Audio" - that's the manufacturer. They actually make some good stuff - I would't have expected Behringer to use that good manufacturing..
Looks like a 797 capsule to me - e.g. Røde.
Jakob E.
clintrubber
« Reply #11 on: July 10, 2008, 07:55:47 AM »
Moby
« Reply #12 on: July 10, 2008, 08:35:16 AM »
That means that capsule can be worth of trying... Mike sounds bad, I mean really bad  :?  So, maybe some other electronics? BTW, can I measure capsule somehow? Does the capacitance means something ?
Rossi
« Reply #13 on: July 10, 2008, 09:03:58 AM »
Quote from: "3nity"
I just had a look at my Studio Projects B1 and it appears to be a very similar or identical circuit, same components, too.
Componentwise there's nothing to complain. Actually it's quite surprising to see WIMA caps in such an inexpensive mic. I don't think anybody has traced that circuit so far. It is probably a pretty clean and linear circuit. The backside PCB appears to be a DC converter for the capsule polarization.
I suppose the overall character is in the capsule, which, since it is a K87/K103 knock-off, has a substantial treble boost. In the U87 this treble boost is compensated by a filter circuit. But that's of course not all that separates the B1 from a Neumann. The TLM103 doesn't use a filter circuit either, still it sounds much better than a B1. It simply has a better capsule.
Moby
« Reply #14 on: July 10, 2008, 09:10:01 AM »
Maybe hf compensation in the circuit doesn't match with capsule? Possible?
vertiges
« Reply #15 on: July 11, 2008, 01:30:50 AM »
Wima caps in a Behringer ???? I'm impressed... :shock:
eD
Quote from: "PRR"
> ...lighting tends to be lazy and typically finds a shorter path (such as my microwave oven).
zebra50
« Reply #16 on: July 11, 2008, 04:30:03 AM »
If it's really bad, maybe something is faulty?
Are those two big electrolytics in the signal path? If so it may be worth swapping them in case they've gone bad.
Be careful - the board will probably melt!
Ribbon microphone services
http://www.xaudia.com
Microphone blog
Moby
« Reply #17 on: July 11, 2008, 07:54:50 AM »
Quote from: "zebra50"
I'm not sure about elcos, that's why I asked for schemo. No, it's not faulty, works normally but with ugly HF boost  :evil:
rodabod
« Reply #18 on: July 11, 2008, 08:03:22 AM »
K87 filters have been discussed here before. I agree about the Chinese high-end - it's pretty nasty, although I've just gone the route of not using those capsules.
Quote from: tv
punchy fat bastard chip
Moby
« Reply #19 on: July 11, 2008, 08:13:13 AM »
Quote from: "rodabod"
Then, if conclusion  is that capsule is guilty for HF it's time to give up....is that conclusion  :wink:
Subject / Started by Last post
Last post June 13, 2007, 12:09:33 PM
by clintrubber
Last post April 08, 2010, 08:52:19 AM
by Disease8
Last post March 29, 2011, 04:49:37 AM
by ruairioflaherty
Last post May 31, 2011, 07:49:36 PM
by V9977
Last post February 01, 2014, 06:49:03 AM
by RMX
