AudioJunkie
How does one test a voltage regulator to tell if it's fried, or if there's just a short somewhere in a circuit? I built SSLTech's power supply point-to-point using a lower voltage transformer, and 15V regulators. The + leg is working, but the 48V and - leg are both coming out at 61V and -30V which are what's going into them from the rectifiers.
I suspect there's a short at the regulators, since their leads are so close, i probably accidentally got solder on two legs at the same time but just can't see it. I've checked wiring and it all looks right compared to the schematic and the board traces.
Daniel
Daniel
