Hi.
I bought this little practice amp, Behr* vtone GM108, and it sounds great.
Actually, it sounds so great, that I plan on recording through it, both guitars and synths. Problem is, that it was not built for recording. It has slight buzzing present all the time.
It is not factory failure, I tried others in shop and all had the same buzz. It is slight, and not heard while practising, but will be picked by close miking. Buzz is the same independently of what is plugged in, and independently of settings on buttons and independently of volume setting. At high volume white noise comes out, but that's fine. I just want to get rid of buzzing.
I opened it (see photos below).
http://84.255.203.119/amp/20081001_0001.JPG
http://84.255.203.119/amp/20081001_0003.JPG
http://84.255.203.119/amp/20081001_0004.JPG
http://84.255.203.119/amp/20081001_0005.JPG
Buzzing is visible on scope. It is not sinusoid, but spikey-triangle-something signal, with 50Hz frequency.
I checked power supply signal, and it is not nice sinusoid. It is like cca. 10% overloaded sine, sinusoid with sharply flattened top with some hi- freq dirt on it, so probably transformer core is overloaded or something.
In power supply part there are two 1000uF capacitors. Should I add in paralell some bigger ones? There seem to be no cheramic bypass caps. Should I add some 100n from both PS rails to ground? (edit: i noticed two ceramic 100n caps hidden behind pot, so there is bypassing)
Or is it maybe inducted noise from transformer, and will not be cleaned by modifying power supply?
What would you recommend?
