tardishead
- Joined
- Aug 11, 2004
- Messages
- 623
Yes I know very decadent and inefficient but what are the dos and don'ts in this topic.
My friend has some awesome old SE tube amps 10 watts. I was wondering if I could push the output tubes and use the units for processing line level signals.
So it needs some kind of power soak. How about simulating a speaker with a 10 watt 4 ohm shunt resistor and then parallel another pad for line level tap????
I had posted about building a 2a3 mic preamp but the overall response was not worth it. I was thinking padding down the output of tube amps might be an easier way of getting the colour from these old tubes at different levels of drive.
