I used the values in the schematicsScreamer said:Does anyone know the values of C19, R54 and R47 for the input transformer VTB9046 ?
kambo said:can you see then "link" on control pcb ... you just put a switch to that, and connect to second unit...
when they short, its stereo... when they are no-short dual mono
EDIT : hope you matched your diodes an both units...
I believe your b drawing is correct. To pull a quote from Reanimator's build docs: "can you see then "link" on control pcb ... you just put a switch to that, and connect to second unit...dacapitan said:kambo said:can you see then "link" on control pcb ... you just put a switch to that, and connect to second unit...
I am a bit confused with wiring up the Stereo/Dual Mono switch. I noticed there is a "Link" on the control PCB and a "LNK" on the mainboards too? - I am not sure if both of these are supposed to be connected to the switch?
The way I understand the quote above is depicted by "B" in my diagram - which is the correct way to wire this? A or B or Neither - Any help will be much appreciated!
duantro said:I believe your b drawing is correct. To pull a quote from Reanimator's build docs: "can you see then "link" on control pcb ... you just put a switch to that, and connect to second unit...dacapitan said:kambo said:can you see then "link" on control pcb ... you just put a switch to that, and connect to second unit...
when they short, its stereo... when they are no-short dual mono."
PM or email me your email address and I'll send it over.prescott said:Can someone upload this again?
The build manual from Reanimatorstudio
The link is not working on the first page.
.....long time ago he start a trhead about ....duantro said:PM or email me your email address and I'll send it over.
JayDeeP said:Just thought I'd post another finished build. Sounds fantastic. I bought the ancient L0116a output transformers from Dan Alexander about 13 years ago.
I have docs. pm or email me where to send them.Spencerleehorton said:Can’t open any of the schematics or pictures?
