APP Studio Ing's products - APP992 - APP14GE Germanium DOA and other kits
ppa
Italy
For contacts just PM me or send me an email by GDIY, thanks
Read for other my products and infos before ordering, please.
DOA'S - DISCRETE OPAMPS
APP14GE
germanium discrete operational amplifier
APP14GE is a germanium DOA that I have developed starting from my MA1 germanium pre.
It's a new DOA so it's not a clone of another one (my own design from my experience as professional electronic engineer). I have designed it both for line and preamp stages. APP14GE uses both a germanium transistor and some silicon transistors. The germanium transistor is placed on the best point "to make germanium sound". As my MA1 preamp, APP14GE, has a warm vintage germanium sound. BTW it can use some different germanium transistors inside for getting different colors.
Kits came with docs with assembly manual (sent by email).
Kitset version prices with the NOS AF127 germanium transistor :
- 19 euro per pc for 1 pc
- 17.2 euro per pc for 2 pcs
- 16.5 euro per pc for 3 to 6 pcs.
- 16 euro per pc for > 6 pcs.
PCB's only prices:
- 6 euro per pc for 1 pc
- 5.5 euro per pc for 2 pcs
- 5 euro per pc for 3 to 6 pcs.
- 4.5 euro per pc for > 6 pcs.
all these prices are S&H and PayPal fees excluded.
APP992
high performances FET input discrete operational amplifier.
APP992 is not a version of the JE990 but a totally new DOA (my own design from my experience as professional electronic engineer). I have designed it several years ago and it's a FET input DOA with modern design topology. APP992 has a trasparent, neutral and clear sound with a FET mojo. Neutral but not cold.
After many years on the market it's a very popular one and is used on many gears as eqs, compressors, pres,..etc...(for example is very used on Sontec eq clones).​
main features:
- ultra low noise (1nV/rt Hz)
- very high slew rate (75 V/uS)
- high class A operation
- drive 75 ohm
- can be powered from +-14V to +-25V , so it can use +-16V, +-18V , +-24V of power supply.
- very stable on unity gain.
assembled version prices :
49 euros pc for 1 pc.
37.6 euros pc for 2 to 10 pcs
36.5 euros pc for 11 to 50 pcs
kitset version prices :
15.5 euros pc for 1 to 3 pcs.
14.2 euros pc for 4 to 10 pcs
13.8 euros pc for 11 to 50 pcs
The docs include the assembly manual. Support is at APP992 thread.
A very good video review on the Don Classics 250EQ with APP992's inside by ShoeTique (GDIY menber) here
MIC/DI PREAMPS
APP Studio Ing. MA1 germanium mic/di pre
This mic pre uses both a germanium and some silicon transistors.
I have designed this gear to have the sound of germanium with the dynamic and the fast transients of my opamps. The germanium transistor has been placed on the best point to make sound. MA1 an high performances gear with a lot of the warm that only a germanium transistor can do. It is designed for 500 rack chassis and so it works with dual 16V of power supply.
MA1 has 64 dB of gain max and can use several trasformers (some of Classicapi, Cinemag, Jensen, Altran and Lundhal),​
PRICES:
ASSEMBLED UNITS: ask for prices, please
KITS:
MID kit version:
- 36 Euro per one pc plus S&H and paypal fees.
- 34 Euro per pc for 2 to 4 pcs plus S&H and paypal fees.
The kit includes:
- chassis accessories: all screws, standoffs, bolts and washers.
- all resistors
- all semiconductors
- PCB
- all capacitors
are excluded the others components:
- chassis : front panel, L bracket, these ones are available at www.frontpanels.de (contact me for them)
- the input and out transformers
- switches and switches' caps (the buttons on the front panel)
- potentiometer
- potentiometer's knob.
BASIC kit version:
- 28 eur per one pc
- 26 eur per pc per two pcs
- 25 eur per pc from 4 to 6 pcs
- 24.5 eur per pc from 9 to 15 pcs
The kit includes:
- PCB
- potentiometer
- all resistors
- all capacitors
PCB only:
- 20 eur per one pc
- 19 eur per pc per two pcs
the PCB is double face FR4 professional with gold plated holes and connectors.
the front panel and L bracket are available at www.frontpanels.de (contact me for them)
support thread: MA1 GERMANIUM mic pre support thread
APP studio ing. "PICCOLO",
GAINCLONE LM3886 power amp card
very high performance module based on gainclone amplifier, PSU included in the same board, so you will buy amp + PSU inside the same board!
APP studio ing PICCOLO (PCB only):
one pc: 8 euros each plus S&H and paypal fees.
from 2 to 4 pcs= 6 euros plus S&H and paypal fees.
from 5 to 6 pcs= 5.5 euros plus S&H and paypal fees.
from 7 to 10 pcs= 5 euros plus S&H and paypal fees.
chassis available at www.designbuildlisten.com
APP STUDIO ING. PSU2 , CONFIGURABLE PSU BOARD KIT
This is an high performances PSU board designed for mic preamps.
I have designed this PSU board for the many requests of API 312 clone channels around here.
For this PSU project I started from the typical DIY preamp configuration of 2 or 4 pre channels inside 1u rack chassis. Moreover, if needed, the PSU can be easy set for dual 24V out for 4x M1 channels. Since the space is very important when there are both 4 channels in the same 1u rack, I gone for a compact size PCB with narrow and long form.
This project was developed around the famous LM317 and LM337 IC regulators, with a design oriented for low noise and fast response to the load's current.
PSU's out voltages are set by 3 multiturn trimmers, one for each out.
the out voltages range is from +/-14V to -/+28V on main outs
The APP PSU2 has dimensions of 5.28 inch X 2.05 inch (13.4 cm X 5.2 cm )
and is made with a professional FR4 two layers PCB.
current specs:
main outs= +/-800mA (with proper heatsink)
+48 out = 50 mA
PRICES:
APP studio PSU2 kit
(S&H prices exluded).
22 euros 1 pc,
20 euros from 2 to 3 pcs,
18 euros from 4 to 10 pcs
APP studio PSU2 PCB only:
from 2 to 4 pcs= 7 euros plus S&H and paypal fees.
from 5 to 6 pcs= 6 euros plus S&H and paypal fees.
from 11 to 20 pcs= 4 euros plus S&H and paypal fees.
Note: Power Transformer not included.
Disclaimer (it must be read before ordering and/or paying):
- These products must not be used inside equipment for sale. Commercial use is denied without written and signed authorization of the product's designer (Pier Paolo Abbate).
- jurisdiction for any legal dispute is Italian, in any case the competent court is the court of Palermo in Italy.
- there is no warranty on these products, the seller does not assume any liability and/or any penalty for them in any case.
- these products can be very dangerous so they are only for persons who are very expert in electronics, if you're not very expert in electronics, than do not buy these products.
- these products must NOT be used for life supporting and/or for military applications in any case.
- these products are NOT suitable for life supporting and/or for military applications.
Thanks all for your interest,
for the first 4 Customers I can send to them very soon the op amps because I've these op amps in stock, for the next customers there is a lead time of a week or at limit two, sorry, but I have ready to send out only 8 op amps, I'm selling three operational I have reserved for me too.
Pier Paolo
doubleroger said:
I'd like a pair of those, please :)
ok, message sent to you with total with shipping cost included to the (very beatiful) Paris.
Pier Paolo
Engfelt2000 said:
two for me please :)
since the raccomandated mail service cost less for Oslo for two op amp and it's 5 euro (the parcel service is 6 euro) the total prices became 45 euro. This shipping prices is the same for all Europe for all European the total price for two op amps is 45 euro.
Pier Paolo
dfer said:
Im in for two
ok, for the Ireland two op amp shipping included are 46 euros,  I can send out soon as well as possible.
Pier Paolo
Tubemooley said:
I will take two of those. I will attempt to PM you or e-mail you right after this. Dana Walcott.
ok, emails just sent.
Pier Paolo
Sredna said:
Ciao Pier Paolo!
Just sent you an email about two DOAs....
Best regards,
Anders
ok, email sent
Thanks and kind regards
Pier Paolo
keefaz said:
Hello, it's 23:41 here, is it too late for 2 opamps ?
no, it isn't but the lead time is around a week for this order, email sent to you.
Pier Paolo
