I am interested in high frequency behavior of normal hole mounted metal film resistors. It would be nice to be able to prototype some high frequency digital circuits without SMD components.
General rule for SMD resistors from memory:
Low value resistors: impedance increases at high frequency (with 1 ohm resistor much earlier than 100 ohm resistor)
High value resistors: impedance decreases at high frequency (with 100 kohm resistor much earlier than with 1 kohm resistor)
The "turning point" is typically somewhere between 100 ohms to 1 kohm.
Philips (is it part of Yageo now?) has published impedance vs frequency graphs for their resistors, but if I remember correctly only for SMD types.
I can't find aywhere the same info for hole mounted resistors. SMD components have been in use relatively short period of time, so someone must have made these measurements.
It is quite strange that resistor manufacturers don't have this info available.
