"SSL desks" is altogether too vague.
The E series imposed a 'sound' on the signal, after it had been through the pres, the EQs, the channel dynamics, the several summing stages, back through the amplifier cards, back through the EQ, back through the dynamics card, through the mix buses and whomped by the buss compressor...
SO they made the G-series more 'transparent'...
Then they made the 9000 series.
No VCAs in the signal path ANYWHERE unless you actively switch them in. -Not even in the master fader. (earlier Es and G's had VCAs permanently in circuit, on large faders and mix bus... and you couldn't take them out). thousands of FET switches removed, and ALL coupling capacitors removed from the signal path within the console.
The notion of an "SSL SOUND" being imposed by the console became an absolute fallacy from that moment on, though many still seem to think there's an 'SSL sound'.
Of course, ALL SSL consoles still allow you to shape the sound in exactly the same way, even adding more options.
But nowadays, SSL 'superanalogue' design really does illustrate an absolutely obsessive drive to make the signal path capable of producing clean, un-coloured, natural sound... while still allowing the same flexible processing ability as that for which they became famous.
So -in short- No.
Keith
