Diy Parts Supply - 3 rail adjustable psu kits $35 (+/-/48V(or other))
Ptownkid
Ajax, Ontario, Canada
Psuniversal 3 rail psu kit
http://diypartssupply.com/index.php?main_page=product_info&cPath=2&products_id=34
SGA SOA 2 doa kit
http://diypartssupply.com/index.php?main_page=product_info&cPath=2&products_id=33
Hey Bryan,
Hows the new dad?  are you getting much sleep?
  did you get your patchbays sorted out?
its great to see that you got your page up here.
have you got your 1176 working yet,  lol
Mike
If the replacement you speak of is the ssm2210 (in dip8 form) it works pin to pin if you cut the bottom 2 pins off, if viewed from the top and counting the dot/cutout thing as the top.
I'm using it in a 9k pre.
Hey Ptownkid! Hows it going? I just went over to your site to check out the Fetboy kit, but it wasn't on your page anymore. Are you no longer stocking it?
I have a couple of questions for you I'm interested in getting a green pre kit I was wondering if you had power supplies for them and if not is there one some where else that will work maybe. Also besides power supply and case is there any other components I would need to be able to finish this project. Thanks
Hey Ptown;
After receiving my turbo kit last week (thanks!) i got it populated today - mostly - i can not tell little yellow 100uf from 100p caps apart.
Scouring them with magnifier for markings but what ever is on them is sooo tiny ...
Two kinda look like they're marked...  1() 1
The other two, a bit like ... 1() G
Apart from this, the kit looks great and straight ahead.
Can you help?
scott
I will have psu pcbs available again soon, as soon as my son let's me get some sleep. Outside of the channel kit, you need a psu, psu xfmr, case, knobs.
