JanusRec
Hey guys,
I'm planing a PSU for my API 312 clone. So the usal +-opamp-supply and 48v rail aren't a problem, as I made similar PSUs for other projects (green...).
But for my API project I want to use relays (like in the Fabio-Design) and found some available which are rated for 6v or 12v.
So how do I get something in between 6v and 12v out of a 18VAC trafo? I'd prefer the 6v soltion the reduce power consumption.
Using half-wave rectification is what comes to my mind first, but I think to recall that it is not recommended because it can drive the transformer into saturation or something.
And just to use a regulator to drop the 21 something volts after the rectifier to 12 or even less volts would really stress the regulator, hmm?
So any ideas for a more elegant solution?
Thanks for your help. Sebastian
