> is there any difference between a 10K-10K for a gain of (2) and a 100K-100k for a gain of (2)?
Take it to an absurdity. 1 ohm and 1 ohm. The opamp has to drive 2 ohms.... it often can't do well. So try 1Gig+1Gig. That's practically no conductance. Most practical opamp leakage, and universal stray capacitance, will overwhelm 1Gig.
For jellybean wall-power NON-inverting design, make your feedback resistor 10K and your shunt resistor whatever the gain wants.
10K is comfortably above usual minimum load (you need some spare for your Real Load), yet comfortably below most audio noise and bias-current troubles.
Then see where you are.
If you hope for gain of 100 down to 1Hz you need a 1,700uFd cap, maybe non-polar. In a jellybean project, that may be large or costly. Take the series resistor to 220K, shunt 2.2K, you only need 80uFd.
Say my PRR741 opamp has input bias current of 1uA. Since there's a cap, this flows in the 220K and induces 0.22V of offset. In a single-supply system, that's often "nothing". Cap-coupled likewise. With no coupling caps, the next stage may be upset about 0.22V DC into it.
Pure bias current on a differential input can be balanced by making the other input's resistor the same, in so far as both inputs suck the same current. They never do. My PRR741 uses floor-sweepings input transistors. I might give you hFE=450 on one side and hFE=27 on the other side. Bias currents won't cancel. (Real opamp makers do much better than my hypothetical opamp.)
You can't reduce all errors to zero. Many errors are not important to a specific design. Figure out what matters (experience helps) and seek to balance errors and costs. If you MUST use 1Gig resistors (as for condenser mike), you can pay for low-low current chips and get <<<1V offset. Though as it happens, a BiFET (TL072) in shirt-sleeve temps will take 1Gig with 0.01V-1V offset, and in audio we just cap-couple that away.
