schokobaer
New member
- Joined
- Feb 14, 2010
- Messages
- 1
Hi everyone!
I cant get the unit working.
I noticed problems with the pinning of BF245A, i found two different pinnings (gate and drain) in the datasheets( on the nxp semiconductor datasheet, the drain and gate connection are different from the drawing in the pdf(component placement drawing)...
(i found datasheets of the same devices with different pinnings), curios.. (-> so i mounted this devices 180 ° turned, compared to gyrafs drawing).
I used BC107A instead of BC107B, which should be no problem..
I measured the voltages(listed on the schematics on gyrafs site).
The following points make problems.
Q2 (B pin 0,06 V instead of 1,02 V)
Q2 (0,06 V instead of 0,54 V)
Q3 and Q4 (1,9V instead of 11,98 V)
Q4 (1,3 V instead of 11,5 V)
I nearly measured all voltage noted on the schematics (in the signal line amp section i just measured the voltage at the output trafo (13,7V -> OK)
BD517 and BD518 were replaced by BD135 and BD136
Furthermore i think the 5532 device is working properly (voltage is rising and falling when using the input pot).
Plz help i cant find any error
greetz klaus
greetz klaus
