Rybow
I want to build something with max ridiculousness. I am already planning on ordering Grayhill rotary switches. $18 compared to the $2 lorlins I had in there before. Why? Well, they are sexy switches. Need I say more?
Anyways, I am trying to find more info about different potentiometer options. I usually just use Mode 16mm pots, but I figured since I am going to sexify the rotary switch, I may as well do the same to the pots. Where can one find some potentiometers that have a little more something something? Are there any factors that will give me a little more performance? 24mm? Wire wound? Manufactured by virgins? Does it even matter?
I will be panel mounting, so the only things I need are a 1/4" shaft and solder lugs. Just wanted to know if the grass is a little greener.
