tchgtr
Changeng,
Like you, I started off modding things by looking at opamps, and my experience and time here has taught me a lot. I've enjoyed Pauls' responses in this thread and have learned along with you about shoring up power supplies.
My two cents...you won't notice as much improvement by playing with ICs as you will from replacing old electrolytic caps, especially in the signal path. I've found that putting signal path bipolars in gear like your Symetrix can help, since these things use electrolytics in place of transformers on the inputs and outputs. Bipolars give better response in the upper mids and high end, that can't be had in 'lytics, except perhaps with some bypass caps... but let's not get into that.
Seems like you can tell which caps are in the signal path, so 'nuf said.
There is improvement to be had in opamps, especially if you are upgrading from something like a 4560, but in mixers, stompboxes, compressors, interfaces, etc. I've found the caps have as much or more to do with the overall quality of sound.
I put some bipolars in the ins/outs of a Delta 1010, based on info from another thread here, and was really pleased with the results.
I'm modding a Symetrix EQ now. Will probably make similar moves with it's PSU.
Thanks to Paul for clearing up something which makes total sense now that I understand what we're doing.
