1176 calibration, no compression . where is the error?
JanusRec
Berlin, Germany
Hello,
here is my problem: after replacing the electronic input of my 1176 with an oep transformer I can't get it calibrated anymore respectively I don't get any compression or always the same amount of compression for all ratio settings.
For the calibration I used my DAW and a DMM and I tried different variants (like balanced, unbalanced); allways got the 1dB drop, but still no difference in compression.
So is there anything I can check on my ratio switch (which I think is ok), or on the main board to find the error?
Thank for your help.
