Fester's TG limiter
StudioSQ
I am having some trouble with this build. Everything seems to work fine except that the unit responds to the hold knob being turned whether there is signal applied or not. The cv test point has between 2 and 5v DC on it depending on where the hold control is set. AC voltage appears when an input signal is applied but the compressor barely responds to it, it does however still respond to the dc. the amp sections work and the AOT trimpots i installed all function as you would expect. when you turn the hold know quickly you can see the attack and release respond and the differnt attack and release position all function correctly. the only thing i cannot get it to do is compress. any help would be great.
here are the files
http://twin-x.com/groupdiy/displayimage.php?pos=-3273
