good points.
never really thought much about mics that were unused but still in the room except a ribbon thats covered.
i hit record just in case any magic happened at a jam once but only the 2nd tomtom mic was enabled that made for an interesting listen back
I wonder about situations like with your beyer 88,
if the mic is not plugged in at all... what determines the natural air pressure resistance without a connected load?
is this more dangerous for the mic than leaving it plugged in and just not using it?
ok ill be careful to direct conversation more with the title in future
i suppose it would be interesting to know why ultra sonic sounds have such an effect on the audio produced from this mic, i thought the frequency response on these was rounded off by design or physical construction.
so, sorry about the title. lets get the safety out of the way, Please ensure your speakers are set appropriately for a Youtube(dot)com video and that you always wear ear protection if you watch this video. but that considered...
I could speculate that the sample rate used interprets elements of these high frequency sounds differently and the result IS actually close to bit/sample rate reduction?
or that the frequencies in question have 'sub-harmonics'? which the mic picks up but are somehow inaudible to humans until played back?
either way i thought a low pass filter or the size of the mic would normally prevent these sounds getting to the media?
