dmp
I've been having a problem in mid-side micing of an acoustic guitar. Following the standard method (below), as the mid mic comes up in the mix, the L/R levels shift, causing the apparent sound source to pan to one side. At first, I thought this was because the sound of the guitar was stronger on one side. But after looking at this more, I think the mid mic is canceling frequencies on one side and summing on the other, because the side mic is phase reversed on one side, and not on the other. If the mid mic were IDEAL (a very narrow pattern), it would only pick up the sound straight ahead, in the rejection point of the ribbon's figure8, BUT with an actual cardiod mic, the mid channel is picking up some of the right and left. This would cause the addition / cancellation with the side mic, I think. The wider the actual cardiod pattern of the mid mic, the worse the apparent panning.
Could this be fixed by copying the mid mic to a second channel, flip the phase, and pan them, like the side mic? Then there won't be cancellation on one side; it would add on both.
Thanks for your help!
MS micing Method:
- Using either a sm7 or re20 for the mid and then a ribbon mic for the side, vertically close together, directed at the 14th fret about 6 inches back.
- copy the side to a 2nd track and reverse phase, then pan L/R
MS micing Method:
