Ive got a small 15WPC amplifier that is ready to put in an enclosure. The output transistors are in TO-3's and I'm looking for some method to heatsink them in a 1U rack unit. The idle current is not to high but when run full open for a while they o/p trans get hot. When in an enclosure I know it will be a bigger problem
It seems I have seen heatsinks that are about 1U high (1.75") and mount to the backside of the rack stretching halfway or so across the width, leaving enough room for i/o connectors. Does anyone know of something like this with TO-3 mounts (4) on it.
How about any other ideas? The TO-3's are not directly mounted on the circuit board, so I do not have that restriction.
Maybe a quiet fan? or an air circulation system? Obviously it doesn't have to be to extreme with this power level.
Thanks all,
Brian
Thanks all,
Brian
