Blue Jinn
Hi
Looking for a simple phantom power project. Seen some people use a B+ and a zener, (don't want to do that) or voltage doubler/triplers (seems more complicated). Came across this:
http://www.alliedelec.com/Images/Products/Datasheets/BM/ALLIED_TRANSFORMERS/227-0165.PDF
115/230 primary 115 secondary. In USA with ~120 nominal house power, so if I wired the primary in series, would this net 60v at the secondary? (And I'm assuming that would be at now ~200mA?) which should be enough to use a conventional ic regulated pwr supply (i.e. boards available) to get a regulated +48v with something like a LM317 (seems to exceed rating) or a TL783 for at least 5-10 mics?
