mich Well-known member Joined Oct 31, 2004 Messages 449 Location Israel Jan 9, 2011 #1 http://cgi.ebay.com/ebaymotors/5-x6-EL-Panel-Sheet-Pad-Back-Light-Display-Backlight-W-_W0QQcmdZViewItemQQhashZitem4155ca8e69QQitemZ280612212329QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories worth a try?
kazper Well-known member Joined Jan 2, 2007 Messages 1,722 Location Snohomish, WA USA Jan 9, 2011 #2 No... I'm thinking you want a AC panel rated for up to 120V. You would be better off just using standard el paneled night lights.
G gary o Well-known member Joined Dec 28, 2004 Messages 1,532 Location uk Jan 10, 2011 #3 I think the actual panel will work I think the little box is an invertor bringing the 12V up.....I might be wrong.... I think it would be intereting to place with either way
mich Well-known member Joined Oct 31, 2004 Messages 449 Location Israel Jan 10, 2011 #4 You would be better off just using standard el paneled night lights. Click to expand... care to point me to an example?
Sredna Well-known member GDIY Supporter Joined Sep 19, 2007 Messages 1,002 Location Berlin, Germany Jan 10, 2011 #5 The ad states that it comes with an inverter so its probably +100Volts. So Id say worth a try! Do you have a possibility to compare with a original T4b?
mich Well-known member Joined Oct 31, 2004 Messages 449 Location Israel Jan 10, 2011 #6 got access to UA reissue for comparison..also NSL-5910 on the way...
