sine_wave
Active member
I'm planning to stick to the original 6 positions (instead of 9) on the Recovery switch. I've been comparing the original EMI schematic to the TG1 build version and the resistors on the switch are similar in value in most positions on each schm. My question is regarding what to do with the positions I'll be leaving out.
On the TG1 build schematic the unused positions (10 & 11) on the 12 position Recovery switch run off to 2 resistors; R208 and R205. Should I do the same with the empty positions I will have after using 6 of the intended 9 positions? BTW, position 12 on the schematic is not connected to anything at all. Why is this? I would appreciate some help on what I should do with the 3 empty spots I'll be creating by going down to 6. Thanks.
