1176 Vishay trimmer pot question. soooo close!
Songguy
Long Island, New York
hi all,
im so close to finishing up my first DIY project! But, I'm stuck on these Vishay trimmer pot leads and pads. not real sure on the proper alignment ???  Vishay says lead A is right below screw adjust, B the middle then C. Not quite sure how to apply this info.
Rev. F schematic
http://mnats.net/files/1176REVFG_SCHEMATIC.pdf
please check out my oriinal post here with Trimmer pot photo:
http://www.groupdiy.com/index.php?topic=33834.msg541068#msg541068
Please any clarification, anyone?
Chris
if you really want to be picky, convention is thus:
A B C
x x x
  x
with the hole in the second row also corresponding to B to accommodate different trimmer footprints.  either hole works.
but as has been said and repeated, just pop it in.
none of your other resistors have a 'backwards,' no exception here.
