JanusRec
Hello erverybody.
After hours of trying to fix my mnats 1176 I'm again prone to give up; so I hope you guys have some ideas what to check, to find the problems.
The facts:
It's a mnats 1176 rotary switch version.
When I switch ratios, I only get small changes in compression.
It does compress though: Sine wave output changes when adjusting the q-bias pot.
I checked all the voltages in the input and GR control amps - nothing unusual.
The unit used to work fine, before I upgradet the input sections from IC to transformer input.
What seems strange:
The ouput pot affects the feedback AC (at point 22). Is this normal - the wiper only connected to the ouputsection?
Switching to "Bypass" doesn't affect the compression/ output level. I checked all the swiched for shorts etc. - no problem there.
So if you any ideas - would be great.
And are there any additional things I can ckeck (resitances, AC voltages maybe)?
Thanks, Sebastian
The facts:
What seems strange:
Thanks, Sebastian
