New Federal AM864 born
DerEber
München-Germany
Dear friends,
this is my first build of an complete unit and I am very happy.
When the Federal came up here I thought "this will be my first tube Limiter".
Now its 2011.
I had ugly motorboating and now ended up limiting the Threshold-pot with some series
resistence. Threshold is going still going down to -14dBu.
I am having a 1:1 at the Input and padded the output with -12db, leaving +16dB gain.
thanks to all for your support and this great forum!
Stephan
Nice job Stephan!  - Looks great!  Congrats.  I dig the white jacket SK7s -  8)
What input and output transformers and chassis did you use?
Also, what are the mysterious looking switches/relays/circuit breakers?  mounted along the back?
for Input I used a 1:1 Malotki that was laying around.
The output is Edcor 4:1.
Where I bought the chassis.....?  I can´t remember. I did this in very small steps over many years now.
But I was lucky to find one that was not that deep. I must have the bill somewere  8)
The misterious looking things mounted along the back are simple pots. It´s the balance mod.
Somehow they are not that usefull for me. My tubes give same voltages at zero and -10db reduction.
Maybe I my meassurement is not correct. I meassured the Plate Voltage, correct?
I also leave the Ug2 pots counterclockwise. When touching one I get more distortion. When touching the other I get more gain. I don´t quite understand why changing Ug2 does not have the same result for bouth tubes. The unit seems to work fine, so I decided to leave it alone. But if someone can enlight me, I´d be happy.
Nice build, I bet it sounds great.
Curious about the capacitors hanging off the back panel.
I have an old AKG N12K power supply that uses a similar mounting system. Is this something you diy'ed or can you buy these caps with that threaded mount?
Mark
Mark
I can still buy them here over Germany. How long this will last, I don´t know.
Last time I ordered one like this for an old Radio repair I waited 12(!) weeks for them to arrive.
Maybe they need to manufakture them just for me.
Also the first caps I saw with the Phonenummer of the company on it  :D
Any chance you could share where you got them and a part number?
The company is:
http://www.ftcap.de/seiten/de/home/home.php
I ordered them at Buerklin in Munich or you get them at mercanteo.de
Hello
I am in the process of building a Federal myself, and I wanted to ask how you achieve these 3 speeds? Are they release speed, attack speed or "presets" with attack and release? (I'd love to get presets )
thomasdf said:
Hello
It is presets.
As far as I remember I changed the C1..... or maybe C1 and R1 together.
Speeding it up will get you near "motorboating" oszilation problem.
I had a spare desk on my switch and I think while switching to smaller C1 I also swiched C5 for highpass.
So my fast  timings do not react on deep bass as much as the slow one.
I can see if I find detailed drwaings about what I did.
Getting a two deck switch for time would be wise. So you can experiment.
best,
Stephan
Hello Stephan
Thanks for your answer. I am interested in having a look at schematics or drawings / notes if you can find them!
Another question, how much voltage is going thru that selector? Which one did you use? I am having a hard time finding a sturdy one that feels solid in the end on which you would have 3 or 4 positions only and that could handle quite a lot of voltage...
Thanks!!
Thomas
Hey Thomas,
I used some Elma switch. I can´t figure out wich one now. the Info is burried in the bills somewere.
But I am quite sure it was Type 1 like in this pdf:
https://www.buerklin.com/datenblaetter/Datasheet_Rotary_Switches..pdf?ch=64190
speed 3 was original timing constantes.
speed 2 I substituted C1&R1 to 0,47 and 3M
                  C5 became 0,004
At least this is what I wrote on my schem.
speed1 I substituted C1&R1 to 0,22uF and 6,9M
                C5 is unknown here, as I soldered some different ones in serie/paralell and had a strange value in the end that worked even if it shouldn´t.
You should thy to make this components easy accessable, so you can experiment without taking the whole thing appart.
best, Stephan
