1:1 ratio modification for 1176 ?
Hey , 1:1 ratio is obvious. -just turn off the detector chain and audio is passing from in to out,without any dynamic change.
Cheers Bo
You have 1:1 ratio in bypass mode.
I redrew the ratio switch for more clarity :
http://www.wuala.com/ricothetroll/public/ratio_switch.png/
Both switches are variable voltage dividers. The left one reduces the quantity of signal injected in the sidechain, defining the actual ratio, and the second one applies an offset to the output of the full wave rectifier, to modify the compressor's threshold (please correct me if I'm wrong). Just interpolate the voltage dividers's values to obtain the ratio you want.
Best regards.
Eric
thank you for answering...but bypassing the gr trigger cirquit you dont have gr meter indiaction :)
...my question is what is the relasionship for modify 1176 to have 1:1, 2:1, 6:1 etc?
cheers
