Hard to tell. I am hearing about some strange things that went on back then. Like Peerless x-formers ending up ind Chicago Transformer cans and vice-versa. Companies used whatever they had back then.
UTC would be pins 1-11 in a circle. Peerless usually had a smaller circle with maybe a pin in the middle.
Ohm it out.
Figure roughly 70 ohms per henry on the pri and 35 ohms per on the secondary for UTC stuff.
Put it on a scope and get some voltage ratios. You will have either an input/output x-former, or a 600:600 bridging. Maybe an innerstage, but rare.
