abecedarian
- Joined
- Jul 17, 2005
- Messages
- 129
Is it correct to assume all equipment makes a noise similar to ground loops even if properly grounded? When I crank my output of my compressors I get very low frequency humming. Even on my Neve I get it. I'm not certain if it's something to look into or just record with lower output so its not as obvious during playback. I have seen pro guys working in Logic and SloTools with audio wave files that are miniature compared to mine. Is that because they are avoiding this very problem? Again, this stuff can play with the mind... is the hum worse today or are the variables like outputs slightly higher than the other day when I recorded and it all seemed so much more quiet?
