Very true, I made the point re-AGC and similarly a final peak limiter or clipper is necessary as the end stop before the transmitter, so much of what is likely to be the end product will be the result of interaction between these devices. Bring it on, lets hear it, but in a complete system, not in isolationabbey road d enfer said:but I'm not sure when the signal has passed the crushing gate of the final peak-limiter there will be much audible difference.
Somewhat; the DSM is FFT-based so it has probably 1024 or more bands of equal Hz bandwidth (about 20Hz wide at 20Hz center, one-octave-wide, and also 20Hz wide at 20kHz center, about 1/100th-octave wide).radiance said:Isn't this what Paul Frindle does with his DSM pluggin?
