GSSL HELP THREAD!!!
hairyandy
Columbus, OH
------Thread Header------
Byzance said:
I don't quite know where to start fault tracing. Anyone got a clue?
Yes - read this thread, looking for something similar. This help section is not meant as a online help-chat, but a place to look up fixes to various problems
I fully understand it's a long read, but there is so much great information and error-tracing information collected here. No matter how the outcome, you'll learn important things from this.
Try to go through this thread looking for answers before posting questions - that way there's a better chance someone will be happy to answer.
If you switch to "print" view (top right) you can use your browser's search function to conveniently search through all posts at once.
When you eventually solve a problem in the GSSL, please don't be shy: Post a short description of your original symptoms, what the fix was, and how you found it. This would be of tremendous value for others stumbling over the same stone..
And oh - don't worry too much: With patience and work, there is a very high success-rate on this project.
Jakob E.
------/Header------
Hey guys,
I just got my PCBs from Gustav last week and then the forum sh*te happened!  Does anyone have the entire SSL help thread backed up?  I'm not necessarily asking for it to be posted here, I'd just like to get it to have locally when I begin this project.  This is my first DIY project.  BTW, you guys all rock!    :grin:
________
So just to recall, are you guys using THAT2180LA without a problem on the SSL compressors??
I'm about to buy some and would like to know, since we don't have that good old data...
cheers!
Attention:
This thread is an archive of possible and tried problems and solutions - NOT a help chat.
___________________
Hi Andy,
Welcome to the Lab, and the addicting world of DIY. You'd be hooked before you know..
We're all here (even a collection of highly estimated design engineers from well-known companies) - just ask, and we'll try to answer...
Jakob E.
Fabio: 2180LA works fine for the Clone, as does -LB
I'm using the 2180LB and it works fine...You should be fine if you use the LA...Are you dealing directly with THAT Corp to buy them?
If we just start another SSL help thread, it will probably grow very informative in a matter of a few days....we should just do it.
Jakob, would you care to start off the thread? would seem most appropriate...
Chris
Thanks Chris and Jakob!
Going to get some LA fro http://www.profusionplc.com :)
cheers!
Fabio
Chris,
This thread is as good as any.. let's just keep it here...
Andy - could you remove (edit) the questionmark from the thread title?
:grin:
Jakob E.
Hi guys...
I am still gathering parts for the SSL clone, and I am at a point to buy the meter, can anyone help me out?
I liked the one tha Jakob has on the site but I don't know the company who produces it, otherwise I had in mind the SIFAM AL29WF, but I cannot find the specs for the meter?
cheers
Hi Keith,
Welcome here.
For the meter to the SSL you'll need a linear 1mA fsd type, NOT a VU-meter.
And you need one that will fit in your box. Sifam AL29 will fit in a 2U, not in a 1U box.
Sifam "Presentor" data found here: Http://www.sifam.co.uk/presentor.lasso
RS components has the Sifam linear-scale meters. The original SSL meter was a Sifam.
For 1U boxes, you'll need a different meter type, something like this:
http://www.herrong.com/CF.htm
RS components has the Kyoritsu EW-60 (order no. 143-3287 - about 34£) that should fit in a 1U box - but better check measures for yourself before buying...
Farnell also has these cheap standard types:
order no 143509 - it's 100uA, but will work with a different meter resistor (20K in stead of 2k)
Jakob E.
Hi Jakob...
I appreciate your help a lot... I am new in DIY ...but I am already hooked on it .....it is very easy to get hooked as you well said .... :)
regards
Thanks for the info on the meters Jakob. I've been wondering what to get and have been balancing the cost vs. cool factor. I think I'm now down to the Farnell #143509 or the Behringers.
On a different note, I just got a dbx 202C for my clone and I have two 2150s available to me as well. Is it OK/possible to mix different vca types in the clone? I'm assuming that since they're interchangeable it's possible but will it adversely affect the sound at all? I'm thinking that I should use the two 2150s for the inputs and the 202C for the sidechain. Would that be OK? Does anyone have an opinion about 202 vs. 215x or 218x as far as sound quality is concerned?
Thanks and sorry if these questions have been answered before...
Andy
You can't use the 202 for the sidechain, as the 202-block option is only for the two audio-VCA's.
The 202 is simply too good to be used as a humble predictor-VCA, that noone will ever hear - so here it is 2150/80 only :grin:
And you shouldn't use one channel 202 and a second channel 2150, as even small differences can and will disturb your stereo imaging.
Save your 202 for a later project - I'm pretty sure that you will need it one day..
Jakob E.
so are the dbx202 vca's more desireable than the newer 2180/2150 series thats?
I thought they were older and inferior to the new ones...
Hey Jakob,
would the sifam presentor meters work?
It looks like the AL19 would fit, but is it linear 1mA fsd type?
ChrisA,
The 202's are nice stuff. The 2181's have at least as good specs. The 2150 is a low-cost solution - although with a nice sound.
The Sifam range of meters - like any meter manufacturer - can be had in all sorts of FSD values. You just order the type you like, and specify a FSD sensitivity, 1mA in this case.
Jakob E.
Thanks Jakob.
I think I found a store here in Los Angeles (where I am) that has the sifam presentors and just shot them an email.
I still have no meter on my first ssl and just started building 3 more, so I thought I'd better get on this.
cheers,
Chris
Hopefully someone who's built one of the on 120v can help me sort through the power situation on the SSL. I'm getting ready to order the parts for this, but everything I've read seems to be based on 220v power. Would anyone be so kind as to tell me what I need to do differently in the power supply section to make this work properly. I'm new to this, so please forgive the basic question. Again I don't necessarily get this, but from what I've gathered, the only thing that should be different is the power Xformer...right???
Also, if you could include part numbers, like for what transformer you used, or anything that might be different from the PCB I have, which is the one from Gustav.
Thank you!
Jimbo :guinness:
[quote author="Ian MacGregor"]Just make sure you've got a nice fuse, power switch, and IEC connector and you're golden.
Ian[/quote]
Thank you for the info! Not to be a total pest, but do you have the part numbers you used for those three parts?
Thanks!!!
Well... You can get a 5x20mm fuse anywhere, I'll give you the number of the fuse holder I used. All mouser part numbers:
Fuse Holder: 5767-345531
IEC Connector: 693-6100.3300
Lighted Switches (expensive!): 653-A165L-AGA-24D-2
Just buy a 1/3A (or so) 5x20mm fuse and you're set.
